Hemi Motor TRQ Specs
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Here is the list for everything you need to TRQ your Hemi correctly
On a few its done in steps so its listed 1) 2) ect
Few of the bolts are also TRQ to yeild as the last step
Cam Gear bolt- 90 FT LBS
Timing Set bolts- 21 FT LBS
Rods- 1) 45 FT LBS 2) 60*
Mains M-12- 1) 28 FT LBS 2) 90*
Mains M-8- 1) 16 FT LBS
Main Cyclinder Head bolts- 1) 25 FT LBS 2) 40 FT LBS 3) 90*
Small Head bolts intake side- 1) 15 FT LBS 2) 25 FT LBS
Rocker Shafts- 195 IN LBS
Damper- 195 FT LBS
Exhaust- 23 FT LBS
Intake- 9 FT LBS
Lifter hold downs- 9 FT LBS
Oil Pump bolts- 21 FT LBS
Oil Pan bolts- 9 FT LBS
Front Cover- 21 FT LBS
Flywheel- 70 FT LBS
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Great post!!
Massey32
5.7 hemi with mds
Sorry to have to ask in another thread but I'm stuck out of desperation. How would I find out if a newer 5.7 would work in place of my 09 Ram 5.7 without programming the pcm. I've posted a thread but I'm new to this. I'm sorry again I don't know what else to do.
DoubleB223
Ky
2017 QC
JBA 1 7/8" torque
do you guys have the torque specs for the headers to add to this list
Im sure it depends on the headers you are using. I know the JBA LT 1 7/8" call for 17ft lbs.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
20lbs for my ARH LTs
John D Martin
British Columbia
Damper- 195 FT LBS
Exhaust- 23 FT LBS
Intake- 9 FT LBS
Flywheel- 70 FT LBS
John D Martin
British Columbia
it' a good thing I found your post on rocker arm rail torque. We almost torqued them to 105 ft lbs not inches. Why would Haynes put inches in the manual when all torque wrenches are in feet? Thanks
Fish on77
Seattle
5.7L
So I went to torque the screws on the cam thrust plate and 1 snapped. Does anyone know where I can find these. They are M5x10 T27
Wild one
14 Sport
What is a good set of bolts to use when changing to long tube headers? Stage 8, ARP?
Use the ones that come with the headers Lyle.You only torque a set of headers to 20 lb-ft at most,and even a grade 3 bolt will handle that.Whens the last time you ever heard of anybody breaking a header bolt,it's very uncommon.Stay away from Stage 8's,you can't get the clips on all the bolts,and you'll want to burn the truck to the ground if you ever have to take the headers back off with Stage 8's.Use a good gasket like a Remflex 6022,retorque them once after a few heat cycles,and call it good.20lb-ft is just past snug with a 6" rachet,as you'll only be able to get a torque wrench on a few of the bolts,and use it to judge how tight you have to tighten the bolts you can't get a torque wrench on
Wild one
14 Sport
This was back in 2019 lol. I just used the stock bolts with the Flepro gaskets. If I would have known sooner, I would have bought the Remflex gaskets. No leaks to date.
Damn i never even noticed the date on your post,i don't know if Red noticed it either,lol
dakotanut
Needville, Texas
What about the sequence of torque for heads and intake manifold? Does anyone have that?
1Popeye
