nickpohlaandp
- Jul 15, 2016
- 741
- 241
- Lake Charles, LA
- 2014
- 5.7 Hemi
So I'm starting this thread to find out just what the title suggests, what is the highest HP you have made/seen/heard of out of a 5.7 Hemi with a STOCK long block (bolt ons are fine)?
My previous history with high performance engines is primarily GM and I've made a LOT of power with stock long blocks, even more with stock short blocks, and even more with 100% aftermarket builds using parts that only mimic GM (Dart blocks and heads, Scat cranks, Oliver rods, etc.). I've even delved into Ford (I know, I know, don't say it) a little bit. I know the old 5.0 blocks were good for about 500 crank HP before you split a block, the 4.6 is a pretty stout platform that will take a lot of abuse when set up correctly, but still 500 crank HP seems to be the magic number of running on the ragged edge for the internals (the blocks are a lot stronger, especially the Teksid), and the new Coyote 5.0 is a huge jump forward with people pushing over 700 crank HP on stock internals.
If any of you have read any of my previous posts, you know that I'm planning on supercharging my '14 Ram and I'm looking to do some research to see what people have done, where the weak spots are, etc. I'm not going to go crazy with boost so I'm not afraid of hurting the internals... yet. Eventually I'll purchase a junk yard engine and build it up with some goodies inside so it can handle some more punch, but in the meantime I'd love to know more about the 5.7 Hemi. I'm really hoping to get some good info out of this. As usual, thanks in advance.
