Apparently "ECO" light indicates the "FUEL SAVER MODE"...This is from a 2010 DODGE RAM 1500 Owners Manual...page 228...
"The FUEL SAVER MODE message will display above the average fuel economy in the EVIC display. This message will appear whenever MDS (if equipped) allows the engine to operate on four cylinders, or if you are driving in a fuel efficient manner. This feature allows you to monitor when you are driving in a fuel efficient manner, and it can be used to modify driving habits in order to increase fuel economy."
From my 2014 RAM 1500 Owners Manuel, page 341...
Fuel Saver Display In Cluster
The “ECO” message is located in the instrument cluster display, this message can be turned on or off. To make your selection, touch the “Fuel Saver Display” soft-key, until a check-mark appears next to the setting, showing that setting has been selected. Touch the back arrow soft-key to return to the previous menu.
and then page 521...
FUEL SAVER TECHNOLOGY 5.7L/6.4L ENGINES ONLY — IF EQUIPPED
This feature offers improved fuel economy by shutting off four of the engine’s eight cylinders during light load and cruise conditions. The system is automatic with no driver inputs or additional driving skills required. NOTE: This system may take some time to return to full functionality after a battery disconnect.
So let me interpret this for everyone who thinks the ECO light has nothing to do with MDS...It has EVERYTHING TO DO WITH MDS - and absolutely indicates that your MDS is engaged...
