I have been searching, without luck forums that address the issues I am having with my 2009 Dodge Ram 1500 SLT 5.7 Hemi (Big Horn addition) without luck.
All at once this morning my airbag and ESP light (as well as the ESP/BAS warning light) came on. The following things don’t work at all this morning as well:
HVAC, horn, windshield wipers or washer pump, bake lights (except the 3rd light on the cab does work, and the tail lights work as well), the rear sliding window, all power outlets, door lock buttons (window buttons work fine), key fob will not unlock (but lights will still flash as if it worked) and the starter assist. Any suggestions?
Could this be a PCM issue?
Thank you in advance!
