If you had $1200
twisted 8
Minnesota
So like the title says I am looking for my next performance mod. I am a little bit torn and hoping that maybe someone can tell me which mod did the most for them. There is three things I am considering, Headers, Camshaft, or 3.92 gears.
I have a 2013 express 5.7 with k&n intake and diablo with hemifever tune. Labor will be free as I can do most the work myself or have someone who can help. I will also be doing all these eventually but just wondering what to do first. :naughty:
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Are you going to primarily use your truck as a daily driver or are you going to drag it every weekend?
Jay
savage_46
Alaska
6.4 swapped
I say put it towards LT headers. My thought process is wait on cam/heads until you know you're not doing any major mods, or done with them. Why spend money on a major engine mod that may not play well with a future one?
Burla
2010 Hemi Reg Cab 4x4
3.92's, but I would go up to 4:10's if I was bothering to upgrade.
huntergreen
gearing would be the most bang for the buck. agree with above, go 4:10 ratio.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Gearing, torque converter and or Long tube headers
Jay
twisted 8
twisted 8
Minnesota
I should have said that it will be mostly just street driven and never go to a track. Would 4.10s be overkill?
huntergreen
just saw you have a 2004, no 4:10 would not be overkill imo. if you can swing it, you might want add LSD at the same time.
twisted 8
twisted 8
Minnesota
oh man I gotta update my profile lol I have a 2013 express sorry
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I'd skip the headers for now and go with 4.10 Gears and a higher stall tq converter. You can have both of these for right at $1000, which leaves $200 for the doctor to wipe the sh*t eating grin off your face every time you hit the go pedal.
twisted 8
twisted 8
Minnesota
What about 4.10 gears and a LSD? Also are 4.10 any different to install than 3.92's
fordtech90
Jonesboro, La 71251
Been thinking bout swapping my 3.92s to 4.10 just don't know if the difference will be worth it.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
^^^^ You will probably not see much of a difference, at least not enough to justify the cost, unless you can do the work yourself.
Jay
fordtech90
Jonesboro, La 71251
Jay
Kinda what i was thinking. Yes I can do the work myself but I'd rather pay someone else to do that. Rear end would be easy. Front end is what I hate messing with. Setting pre load and shimming bearings and re tightening them damn crush washers suck.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I agree with Jay. Going from 3.92 to 4.10 is such a minimal increase that you wont feel enough change to justify the time and money for that swap.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You definitely want to have an LSD i you run 4.10's and a converter. The install is the exact same for the 3.92's or the 4.10's, and labor cost should be the same if adding the LSD because that has to come out to install your new gears anyway. I would definitely consider adding those upgrades at the same time.
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
You defiantly want a LSD if you run a 3:92 and a converter.
twisted 8
twisted 8
Minnesota
Could o do the converter later? Or does/need to be done at the same time
