Kotta390
Holy hell that thing took a small beating to get off. I barely have 20k miles on the truck and I had to use an air hammer to remove it. Normally you just bump the air hammer on the big nut and it breaks loose, but mine had to be hit about 3-4 times and finally broke loose O.O
Anyways I guess I will see if there is any difference. My tuner has already set my fan setting for my stock thermostat to come on at 210F and shut off at 204F
