yillbs
- Dec 13, 2016
- 996
- 498
- 2016
- 5.7 Hemi
I wish I had 3.92 over the 3.21 with the 8 speed. I can deal with the 3.21 as long as it doesn't put a lot of strain on my tranny and motor over time and make them fail early. I still have to get use to the low of a gear. It seems from what I read that as long as I have the 8 speed tranny the 3.21 are perfect for 35" tires and 6" lift. Hopefully it holds true
You're fine. When your cruising down the highway at 1700 RPM.. it's 1700RPM regardless what's behind you. It woudln't matter if you're towing 10k pounds, your engine RPM is what the " load is ". If the high RPM's are constant in order to keep the truck moving, then you're likely going to have a fault earlier than if you didn't. That's actually a benefit to the 3.21 gear ratio. In 8th gear, at 75MPH, you're sitting at about 1550 - 1600 RPMS.. the 3.92 can't do that Granted... that's about the only " benefit " you get, but you're certainly not losing, the 8 speed makes up for ANY difference you could possibly come up with.
That's why it's so hard to use 8th gear with 3.21 gears. The torque at 1700RPM is so small, going up even the slightest hill requires you to downshift. Hence why a few people don't like the 3.21's. It's all about perception, 1st gear is geared so low, it's honestly a moot point, you'll take off at the line just as fast as any other chevy
