Long tube headers vs Shorty headers?
CTD
Southwest, VA
Sounds damn good. :happy107:
Just a heads up when you get a chance to look under the truck, you might want to check out the brake line's and wrap them in some cool tape. I don't no if this is the case on yours but my Y sets pretty close to the brake lines on the drivers side. Hears some pic's of mine before the cool tape in this trend.
http://www.ramforum.com/f44/arh_header_question-106634/
eljefe
Moyock, NC
Damn that sounds good.
BEAST19
Where did u take those photos from underneath?? I had a shop put em on and he did mention having to move a few things.
CTD
Southwest, VA
Yes from underneath the truck. The pic's were taken where the headers connect to the Y pipe on the backside of the frame under the drivers side door. It is very unlikely that the shop moved the brake lines, they where probably referring to the oil dip stick and the trans cable. It is not a major deal, but is a good idea to put sort of shielding on them. Here is another member with the same headers with some pic's that you may be able to see a little better. Link below.
http://www.ramforum.com/f44/arh_headers-99875/index3.html#post1504509
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
To quote my mechanic. They fit like **** and took forever to get installed especially with the stage 8 bolts. I got the bbk shorties and new factory gaskets.
BEAST19
Thanks that helped .... Check this out ... I think I'm good. What do u think ?? I wish they came ceramic coated I wasn't willing to go thru the hassle of having to send en and have em done 229e27c82e34571d998a4dce9285638c.jpg
BEAST19
Ok just had headers installed yesterday... Making a log for Sean and my Hemifever ... Threw these codes literally after doing a 0-60 run twice.... 7d478d93f6ab88e328cdaf6f971ed0f8.jpge2a602257b3d6dc2e9e99365cca6d0e5.jpgd08629c3d9035d658656756998b822b0.jpgc634699334f3ebf9009733d652a5e6bc.jpg Anyoje else experience this????
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Circuit codes generally mean you have a wiring issue with the rear sensors. I would make sure they are plugged in properly and that he wires didnt get pinched or pulled out of the connectors.
CTD
Southwest, VA
That part is fine as it already has some factory shielding on it. If you follow that heat sleeve towards the back of the truck about a foot or two from where you took that pic you will see the black plastic line bracket with the two unprotected black brake lines sitting close to the Y pipe. That is the part where there needs to be some shielding if sitting close to the Y.
CTD
Southwest, VA
Has far has the codes go it looks like some sort of wiring issue with the O2 sensors like Hemi450 stated. Check the connectors and make sure they are plugged in all the way or you could have even received a faulty O2 extender harness from ARH. Either way it is probably a simple fix.
BEAST19
There are two plugs on the passenger side that are right next to each other ... One black and one white... Wondering if they could have got those to switched up and plugged into the wrong plug. I wonder if I switch them if I'd risk messing something up???
BEAST19
UPDATE:
May have figured it out! Checked the o2 sensors numbers and locations with the ones from dealership , one was out of place along with one of them being a wrong number??? (Keep in mind they were my stock o2 sensors) anyways cleared codes and moved sensors , and ensured all wiring and connectors were good... So far no code.... Drove probably 20 hard miles so far.
So learn from my installers mistakes.... Don't mix up the o2 sensors when swappjng from stock to longtubes. !!! Fingers crossed it was a simple fix
dstryr
The one and only
IA
Which is better? I need some advice
definitely go with long tubes. without any head porting or other work the headers should be sized for the head flow; too small will slow the exhaust gasses down, too large the exhaust gas velocity will not be sufficient to scavenge the exhaust gasses while the intake valve is opening and the exhaust valve is closing. The appropriate velocity will draw more of the burned a/f mixture from the combustion chamber resulting in a better fresh a/f fuel charge and more hp. The longer tubes will help maintain exhaust gas velocity until it gets to the collector.
