U&A
- Apr 29, 2016
- 9,261
- 18,563
- Michigan
- 2016 3500 SRW
- 6.4 HEMI
thinking about putting some magnets on the SIDE (not the bottom) of the oil filter. use to do it on my old truck with no problems. anyone else do this on your engine oil filter? never seen or heard of any issues with it besides the concern of putting it right under the bypass valve for obvious reasons. the more "edges" or length of edge on the magnets you have the more surface area you have to collect iron debris.
one would assume that there should be no concern of flow issues (when used on the sides of the filter) in normal circumstances. If you have enough wear to cause enough buildup to restrict flow than something else is wrong. IMO.
the "filtermags" seem WAY to expensive so ill probably get something else.
FilterMag International |
thinking of getting a handful of these if they seem strong enough.
https://www.menards.com/main/tools-...440112530-c-19644.htm?tid=6093498968470813758
https://www.menards.com/main/tools-...440128751-c-19644.htm?tid=6093498968470813758
