Hey Everybody,
I have lurked around this board forever, and am needing some help. My truck is a 2014 Express, RCSB, 2wd, Hemi, with a 65RFE and 3.92's. My plan when I bought the truck (admittedly before doing any research or I most likely would have ended up with a Chev - their aftermarket is just so much larger it seems), was lowered, with a blower and a 6 speed stick swap.
I love the torque PD blowers make, and after doing a ton of research I don't think there is a way that will make both me and a 65RFE happy with a TVS2300 on the Hemi. I have heard L and M can build a great tranny, but I'm not really into the whole lift to shift, down shifting manually to pass on the highway etc. It just seems like a bandaid.
I love driving standards, and would like to put a T-56 in the truck. Weight would be similar enough to the heavy Challengers that I don't think the gear ratios would be and issue, and I may go to 4.56's anyway. I need help with the technical stuff. I know I am looking at:
-tranny (really a takeaway from any 5.7 R/T should bolt up as far as I can tell) Stock tunnel should be fine, hole in floor for shifter no biggie
-Crossmember
- Driveshaft
-Clutch pedal assembly, and secondary clutch fluid master and line
- 8 Speed steering column covers to remove column shift
That stuffs straight forward. I'm worried about the tuning. Will the ECM/PCM freak out? Can you tune the auto inputs out, and the t-56 inputs in to retain stock speedometer?
I don't believe this swap has been done on a 4th gen, why is that?
Appreciate any input, hoping to make this informative for anyone who wants the same swap.
Thanks!
Pat
-Crossmember
- Driveshaft
Thanks!
Pat
