I've been waiting for a "blem" set to pop up so I can do similar. I do a lot of custom firearms cerakote work and have a room full of different colors.
Just FYI, 275 for 2 hours makes it more durable than 315 for an hour. I have both heat cure and air cure graphite black so will probably just spray in whatever I'm loading up next. Most likely the heat cure, it holds up better, I don't care what anyone says. I've done many suppressors in the air cure as it has a higher temp rating, and it holds up to full auto suppressor fire decent, but in general scratching doesn't seem to hold up nearly as well.
