Moe's driveshaft
RamonaRt
Texas
Has anyone on here installed a Moe's aluminum driveshaft on there single cab 8 speed? I can't seem to install mine it's just a bit too long, I can't bolt the other end.
averageguy
Belleville Mi
hemi
Are you sure the front is in the tail shaft as far as it will go? Maybe pull it back out a little and push it back in hard. If it goes a little too far no big deal, just line up the back then pull it back out.
