I swapped cam and lifters end of Jan of this year due to cam failure with some help from Jay Greene. A few days ago I stepped on it to get in front of traffic and it sputtered and then returned to normal for the rest of the day until it died on me waiting to turn. It will start but sounds terrible and has no power. Autozone was the closest placed so I had them read the codes since there was a check engine light. They said there were none. The next day I rented a scanner and checked myself. These are the codes I pulled:
P0118-Engine Coolant Temp Sensor High Open
P2008-Short Manifold Runner Valve Control Circuit Open Bank1
P0113-Intake Air Temp Sensor Circuit High Input Problem
P0108-Manifold Air Pressure Barometric Pressure Sensor Circuit High Voltage Input Problem
P0123-Throttle Pedal Position Sensor/Switch A Circuit High Input
P0222-Throttle/Pedal Position Switch/Sensor B Circuit Low Input
I took it to a local mechanic to see what he says about it but nothing as of yet. Any help would be appreciated.
