So, had a FM muffler installed yesterday. Apparently, the stock muffler is super heavy compared to the FM and now my truck is 3/8 of an inch higher on the passenger side due the huge weight difference in mufflers. Anybody else notice this?
I got the 32 gallon tank option, when full, my passengers have a hard time opining their doors cause of the lean)))))))
The stock muffler might weigh 40 lbs total .... I just replaced mine last week myself ... probably closer to 35 lbs imo
Your lean is likely from fuel level in the tank.
Gas weighs approximately 6.5 lbs per gal . The tank is on the left side at about the same location as the muffler .
If you have a 26 gal tank like me .a full tank weighs about 180 lbs and you probably just lost about 25 lbs with the muffler removal & FM install so at a full tank you now weigh about 205 lbs more on the L/H side .
Hope this helps !
6.183 lbs per gal , I said approximately3.8 liters is 1 usa gallon = 6.1 lbs not 6.5 lbs
Lol. Leaning because of a muffler swap? Awesome.
What the F would happen if a fat chick got in your truck? *****
Can you please post this?the manual says the mid grade 89 octane is recommended for these trucks.
