I put non mds lifters and cam in my 2012 ram hemi and now it does not rev over 3500 and is not shifting right also cam position sensor came up I need help please respond
Possible that the cam/crank is off a tooth. Some cams don't line up using the factory marks and need to have TDC set using the rod on the piston technique instead of the timing set marks.
Since you have a cam you need a custom tune; in the custom tune the tuner needs to disable the MDS system. If you don't have a custom tune then your tuner will have an option to disable the MDS.
I would buy a Diablo I2 from either Moe's or Greene Racing, both will get you the programmer and a custom tune from either hemifever (Moe's) or Jay Greene
