1500 miles should be fine Sir , different 5.7s and diff driving styles will yield quite a bit different results .Ok was going to check mine again at 1000 but will probablygo 1500 and see
EJR_3 did you buy a billet tech occ . Mine came with a spacer to put between the bracket and the head so the wires could run behind it.
On another note, you can use 'Trip B' on your on board computer to easily track how many miles since last dump .
Sir , be sure to post your dump after your 1,000 mile towgonna be towing ~1000 miles tomorrow. Should be interesting to see what I get out of mine. Typically I fill the can half way between 5k oil changes
You may be shanking out on the bolt shank , all engines are a bit different!Yup, have the spacer installed as also. Got the bolt in nice and tight, but with a little force I can still rotate the bracket towards the fenders. I don't want to over tighten it and make things worst.
Wow ! That looks like my dumps !After 3,000 miles on mine
My Fellow Tally RAM OwnerAfter 3,000 miles on mine
