Egor
How does it calculate when it's due and can you trust it when you run full synthetic?
If you run that thing you will be changing your oil too soon. If you are running something like Mobil one, just change it every 6 months up to 10k miles. Look at synthetic filter like Royal Purple or Fram Ultra. 2011, I think you clear that code by turning the key to last point before start, pressing gas three times, and turning off then on? Just clear that and ignore it and run your own program. Every six months is perfect unless you are running top top tier oil and want to run it longer. Then play the uoa game and they will tell you what is a good oil change interval. check out syn thread.
