Oil change how much oil? 5.7L
stevens
2015 Dodge Ram sport 4x4 crew
got pennzoil ultra premium our trucks take 7 quarts correct? just confused on the value....is 7 quarts 6.6L and a bit? i got 2 5L jugs...
Burla
2010 Hemi Reg Cab 4x4
Just don't fill up to the top after the change, let the level on the stick after you put back 90% dictate how much to add to hit the top of the line.
grizzstang
Calgary, Alberta Canada
According to my convertor app 7 quarts is 6.6 liters. So I would dump one whole 5 liter jug in and then just one liter out of the other 5 liter jug. Start, let run and settle then top up as needed. In theory it would be about a half liter low (still in the safe range but not full), better to top up than overfill it.
BiGMERF
Florida
2017 SLT 4x4
v6
got to find out how much for the pentastar.. ll
Burla
whetrick1
My 2016 holds 7 quarts by the owners manual.
BackCountryAK
2017 Crew Cab & 6.4' bed
Added 7 qts and the dipstick is reading high. It's past the upper mark/hole, almost to the little "s" bend on the dipstick. Truck had sat for a few hours and was sitting level when I took the reading.
Before I swapped out the factory fill the oil measured to the "E" on "SAFE". Oil pressure still seems to be higher and I wonder if it's because there's too much oil now? Do I trust the dipstick or just keep using 7 quarts since that's what the manual calls for? Never had this problem before in my previous 2 dodge rams.
Burla
I have the opposite problem, my Ram takes 8 quarts to fill the dip stick. I have went off the dip stick the entire time, I've never needed to add any oil ever during the oci, which makes me happy. I never had an issue, but it has always made me a little uncomfortable.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Burla are you running the Big filter ?
Mine took 7 quarts and was at the top of the full mark on the dip stick.
Backcountry, did you check your oil after start up ?
BackCountryAK
What's you oil pressure before it warms up? Mine is high 50's/low 60's while driving. It only drops to low to mid 50's when it's at 220 F. I swear it wasn't like that with the FF.
BackCountryAK
I've only checked the oil when the engine is cold. I am running the smaller filter btw.
kevperro
Pentastar 3.6L
Pentastar is 6 qt capacity but I only get 5.5-5.7 drained. If you use 6 quarts it will be off the high end of the stick. I measure what I drain and then add what came out. Check on the stick once it has been run and sit for 15-minutes.
I'm right at 30,000 miles and I'm running the current fill until 35,500 and getting a Blackstone analysis before it goes off warranty to check for possible fuel/coolant leaks.
Burla
Usually 55 psi
Burla
20-820 rp
