SirGeorgeKillian
- Nov 1, 2012
- 121
- 20
- 2016
- Hemi 5.7
Long story short, 2 weeks ago I changed my own oil on my truck for the first time. The filter was on extremely tight but when I got it removed I checked that the gasket came off with it. It did, I even stuck my fingernail into the gasket to see if it was rock hard after it was torqued on so insanely tight. I went on with my oil change as planned (using the recommended one full turn after gasket contact).
Fast forward to yesterday, I'm driving into work, and the truck alerts me to low oil pressure, it was showing 2psi. I immediately pulled over and shut the truck off. Went to pop the hood and oil was dripping down the front of the passenger side headlight. Get it towed to the dealership and they say it needs a new engine and that they found two gaskets on the oil filter. I said that is impossible because the old one came off with the old filter, I visually checked that. They claim they can't warranty it because despite what I saw the oil was incorrectly changed. I asked if they could certify that it didn't come from the factory with two gaskets (stranger things have happened) and they said they could not, they could only go off of the information they have in front of them.
So now I'm faced with a 2016 with 9k miles that has a blown engine. Anyone else ever had this happen to them? I really don't want to fork out for a new engine, and they are saying to check with my insurance to see if they would cover it which I obviously don't want to do since I would more than likely end up paying for with higher premiums over the next who knows how many years. Advice or suggestions?
