I dig oil stop, they give you credit if you bring your oil or filter or both. You pay like 40ish if you bring oil and filter and they will even take the coupon as well making it 30. But they give you a drink, check all your ****. The have a decent pricing structure for everything,
check this out. With coupon I think it was 42 out the door for the wife's car, she takes 5 qrts. All you have to do is say no thank you for all of the extra services. But it is real cool they check everything. So they wouldn't be over 50 bucks with coupon for Hemi, but that is with their chevron oil. If you bring a case plus one mobil 1 from costco it would have been less then your jiffy blend job, and they give you a free soda or coffee while u wait in the car. To be honest, the cheapest way to get an oil change is any shop in town that has those coupons, but OilStop is so convenient, it isn't funny. Really good for dif and transfer cases for folks that aren't used to doing that as well.
I forgot, the coolest thing about them is they tell you the condition of your drain bolt. They are so hyper aware of drain bolt they have replacements for every model. They always comment on how it was torqued as well. Since I do my wife's about 50% of the time, I know I put the bolt back with the least torque possible. They always comment, man that drain bolt was perfect, not too hard like others they see. It's no ********, you pick the wrong shop later on you might find yourself replacing an oil pan you didn't need to, or at least drilling a new repair kit in.
