So I was installing my new LEDs today and noticed a bunch of oil all over the bottom of the truck. CV shafts and boots, steering rack and boots, trans pan etc... Checked oil level and it just barely touched the, "add oil" mark on the dip stick. About a half quart low.
I went to the car wash and cleaned the hell out of the underside then went for a drive.
To me it looks like it's coming from the k&n filter. But, it's nice and tight and I always make sure the old filter seal is off before I install the new one. It really looks like it's coming out of the hex head on the end of the filter.
I did a Google search and saw quite a few instances of people having this issue.
Have any of you?
This has me pretty freaked out. Never had an oil filter leak before.
This is the first truck I've owned that still has a warranty as well. So I'm kind of wondering if I should just have the dealership fix it? I just don't know if they will give me hell for the LEDs and my s&b intake. It's cheap enough to just go get a Wix filter or a Mopar. Should I just swap it out myself and keep an eye on it?
Have any of you?
