Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
Pennzoil Used Oil Analysis Program!
This is a discussion on Pennzoil Used Oil Analysis Program! within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
Nutshell: Here is a thread that Gena posted in... http://www.bobistheoilguy.com/forums...y_#Post3856727 She has the last post! Just click on her name ...
Like Tree107Likes
Sponsored By: Moe's Performance
Reply
Old 09-23-2015, 08:09 AM   #11 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
She has the last post! Just click on her name and send her a PM and tell Her you would like to participate..
To save some time... Give Her your name and shipping address... Also she will ask for a phone # as well... for shipping purposes... Make sure to tell her what Viscosity you prefer as well... {She will be willing to answer any of your questions}...
Hope this helps...
She has already shipped out Kits... A few members of BITOG has already received the kits and posted pic of the the Kit... So this is no scam or gimmick!
I just received the Reassurance from Gena that there is NO cost in this program the UOA is Free as well!
Sponsored Ad
Register to remove this ad.
__________________
2014 Bighorn SLT 1500 QC 4WD 5.7L BW44-44 8HP70 3:92s w/Anti-Slip!
Oil: 6Qts (GTL) PUP 5W-30 / 1Qt (GTL) SRT 0W-40 & 4oz ZDDP Plus w/RP Filter!
Front -8HP70/T Case- Rear: RL 75W-90 - Red Line D6 ATF - RL 75W-140/90 Mix!
Coolant: Peak Global Lifetime w/RMI-25 Air: AEM Drop In {Dry-Flow}! No CAI!
Fuel: (Shell) 89 w/6oz TCW3 or 24oz Soy Ultra / Neutra! Mileage: 24,429
SyN is offline   Reply With Quote
Old 09-23-2015, 08:44 AM   #12 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Cool. I run Amsoil in my Harley and my HHR. I'm thinking about my truck getting synthetic, but it is an old worn engine. Probably not worth PUP.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 09-23-2015, 08:53 AM   #13 (permalink)
Ram Year: 2014
Engine: 5.7
Default
Sounds like a great deal!
I'd enroll in the program if I wasn't already swimming in oil from my current stash. (I'll still have ~3 cases~ left by this December,,, might be 'out' by 2017,,, That, and I currently have (6) filters on hand as well. LOL!)
SyN likes this.
__________________
If there are particular members that bother you and you do not want to see their posts, then you can add these members to your 'Ignore List'.
Go to User CP, Settings & Options, Edit Ignore List. Then, type their name into the empty text box and click 'OK'.
SlowRoller is offline   Reply With Quote
Old 09-23-2015, 08:59 AM   #14 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
Jimmy: In my opinion-->If your old worn engine does not burn {Any} or very little oil between oil changes nor have any oil drips or leaks...
I see no reason why you can't do this program... It's Free!
How many miles does this {Old Worn} engine have on her?
__________________
Old 09-23-2015, 09:24 AM   #15 (permalink)
pickupman66's Avatar
Ram Year: 2009
Engine: hemi 5.7
Default
I switched over to PUP this past year and so far so good. I need to do a UOI on it since I got one with the amsoil. I have 130,000 miles on my Hemi and as of the last UOI, there was very little wear to speak of. it is well broken in and does not use any oil.
SyN and Esdd67 like this.
pickupman66 is offline   Reply With Quote
Old 09-23-2015, 12:55 PM   #16 (permalink)
Burla's Avatar
Ram Year: 2010 Hemi Reg Cab 4x4
Engine: Hemi
Default
All oils can have sediment from sitting, even Redline can. Do not worry one bit unless you cut the bottle open so you can feel it and there is any gritty feeling to the sediment. That sediment is nothing to the sediment that comes from the combustion process. Even though all of the additives are oil soluble, doesn't mean things wont fall out of suspension from time to time. Couple heat cycles and trips through the oil pump all is well. Next time shake the bottle and get those additives back into the oil
You can always post a pic, but most sediment is very normal.
SyN likes this.
Burla is offline   Reply With Quote
Old 09-23-2015, 08:19 PM   #17 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
167000 miles and she smokes when I start it up and knocks quietly.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 09-23-2015, 10:03 PM   #18 (permalink)
Ram Year: N/A
Engine: N/A
Default
interesting, glade i found this considering pennzoil platinum on my 2015 ram an next oil change. is this the best oil they have out now that claims to be from natural gas? if i read right they will supply the oil? and the test materials? do you have to pay for the test or is that part of the thing they are doing?
ram5.7hemi is offline   Reply With Quote
Old 09-24-2015, 11:17 PM   #19 (permalink)
thad8403's Avatar
Ram Year: 2014
Engine: hemi 5.7
Default
I just talked to her today and they're shipping some oil to my house along with the test for free.
Sent from my SAMSUNG-SM-N920A using Tapatalk
R.L.K. and SyN like this.
thad8403 is offline   Reply With Quote
Old 09-25-2015, 06:09 AM   #20 (permalink)
Ram Year: 2015
Engine: 5.7 HEMI
Default
I'm running this in my 2015. I dumped the factory fill at 2500 and over the last 1000 miles I can definitely hear the motor is much quieter...not that it ever made any noise.
Nutshell is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
pennzoil platinum synthetic oil and filter... ram5.7hemi Engine & Performance 13 09-21-2015 01:19 PM
Black Stone Used Oil Analysis RoadKing Engine & Performance 16 07-05-2015 12:29 AM
Pennzoil Ultra 0W-40 762-MM Heavy Duty 8 06-01-2015 04:02 PM
SAVE $2.4x or $3.4x per qt. Pennzoil Ultra at Pep Boys. jasper302 Engine & Performance 0 03-14-2015 12:58 PM
BlackStones Amsoil Analysis Gunz86 Engine & Performance 8 08-20-2014 09:29 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
