I'm posting this here in hopes it helps someone get rid of their Hemi tick. So guys here's the list of all the oil changes my truck has had. I really wasn't good about keeping track while I was experimenting so some are from memory and a lot of the mileage is approximate until recently. Keep in mind I do most of my oil changes by time, not mileage because I have a company vehicle and only drive my truck 5-6000 miles/year.
*FF (PYB 5w20) MO-899(larger pre-2013) filter installed at factory - Smooth and quiet at all temps
*PYB 5w20 at 750 miles (first wear metal flush), MO-339 filter from Amazon - Smooth and quiet at all temps
*PYB 5w20 at 1500 miles (second wear metal flush), MO-339 filter from Amazon - Smooth and quiet at all temps
Things went south after this. I knew I was going with a synthetic and I had been a long time M1 user. But Pennzoil had the MS-6395 spec and M1 didn't so I figured PP was the synthetic oil I should use. I was by far an oil greenhorn at this point.
*PP 5w20 at 2500 miles (non GTL), MO-339 filter from the dealer - Smooth and quiet at all temps for about 200 miles then developed the hot idle tick
*PP 5w20 at 3100 miles (GTL), got another MO-339 filter from Amazon figuring the previous filter might be defective - Cold start rattle/tick, loud hot idle tick
-3200 miles, Took to the dealer, was quickly told this was normal Hemi noise.
-7100 miles, cold start and hot idle tick worse, took it back to the dealer and was asked to provide receipts to prove oil was changed. I watched 2 different techs listen to it along with the service manager. They showed me another truck they were working on that was at operating temp and it made the same noise but FAR less obvious. I was again told it was normal Hemi noise. I figured at least it was documented twice now.
*Used a free dealer oil change coupon (PYB 5w20) 7300 miles, Mo-339 filter was installed - Immediate quieting of cold start tick and hot idle tick was significantly reduced.
*PYB 5w20 at 8000 miles (to prove PYB was the FF and what the dealer used), Left the same filter - Just as quiet as the dealer change.
Somewhere in here I found this thread and learned about moly, Redline, Amsoil, etc. Read the entire thread to what was then the last post and realized I didn't know much about oil.
*Not 100% sure about this one, but I changed it again around 9000 miles with Amsoil OE 5w20, RP 10-48 - Quiet on startup, hot idle tick was worse. Brought it to a local mechanic and he said a lot of Hemi's sound like this and didn't hear anything alarming. Had a recall to do at the dealer so I had them check it out a third time. Again, I was told this was normal and that they wouldn't look at it again for this unless it was "significantly worse". 3 times documented now.
*PYB 5w20 at 10000 miles, RP 10-48 filter - Quiet on cold start, hot idle tick better but still there. Ran a UOA on this.
*Redline 5w20 at 12500 miles, RP 10-48 filter - After 500+ miles Quiet on startup, hot idle tick significantly reduced but still there. I was amazed at how smooth the engine ran after putting RL in.
*I don't remember the exact mileage here but I tried Amsoil SS 5w20/30 mix, Wix XP 57060. It ran about the same as Redline 5w20.
-Switched to Amsoil SS 5w30 after about 150 miles (yes I'm crazy). Thought I had found my oil only to discover after about 400 miles I had my cold start tick back. Hot idle was still pretty quiet though.
*Redline 5w20 at approx 17000 miles, RP 10-48 - Nice and quiet on cold start but hot idle tick was a little louder than Amsoil SS 5w30. Ran a UOA on this at 1532 miles into the run
*Redline 0w30 at 22800miles, Wix XP 57060 - Quiet cold starts and quiet hot idle tick. It was the quietest my Hemi has run overall since before PP 5w20. I was extremely happy with this and then I got into the Pennzoil UOA program. Ran a UOA and copper was elevated.
*PUP 4qts 5w30 & 3qts 0w40 at 26981 miles, Wix XP 57060 - Quiet on cold starts and quiet on hot idle until the last 2-300 miles, UOA looked better than the previous UOA
*PUP 6qts 0w40 & 1qt 5w30 at 30289 miles, RP 20-820 - Quiet on cold starts, dumped after 400 miles due to hot idle tick
*Redline 5w30 at 30672 miles, Same filter as above, - Quietest my truck has run since new at all temps.
Pretty sure I got everything. I'm done experimenting with oil, just going to run Redline 5w30 and a RP filter going forward.
After seeing this compliled into a list, I can see why my wife was starting to think I had an oil obsession lol
Hope this shows what oil works and what doesn't for a ticking Hemi!
