Post your latest oil change
PCT
2019 2500 6.4
Northern California
I have one coming up, going to run a UOA to see if k&n actually let in significantly more silicates or if people are full of ****
AFMoulton
Nuevo Mexico
People are full of ****, I've run 4 UOA's with my K&N and no increase over stock. Save yourself the money if that's all you are looking for
First is stock filter, rest is with K&N.
Reactions: PCT
PCT
2019 2500 6.4
Northern California
I don't have a baseline with paper filter, just want to see if I'm with in "healthy" limits. I had a home made intake system on it so I may have to run 2, if outside the healthy limit.
james.kaschmitter.90
5.9 cummins
2006 dodge ram Cummins 3500 srw, 351,654 miles, Wix oil filter, Shell Rotella 5w30 T6, 3 gallons, change oil and filter every 7000 miles
Sent from my SM-G935V using Tapatalk
R.L.K.
Bristol , Tn.
Damn your doing 4+ oil changes a year at that average ....what do you do Sir that requires over 30,000 miles a year driving ?
5.9 cummins
Used to deliver travel trailers, ordered the trk from the factory so it was set up the way I wanted it, took delivery in Feb of 06, started delivery of trls in March same year, and by 2nd week of Dec that same year had exceeded my 100,000 warranty. Used it one more year, then bought a Freightliner so I could deliver 2 or 3 at a time. Quit doing that in August of 2011 and most of the miles on the pickup since then has been from running 100 miles a day round trip for work
R.L.K.
Bristol , Tn.
Wow , welcome to the Ram Forum Sir !
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Nice! That's the same oil/filter I ran in my old '01 F250 7.3. Bought new in '01, sold to my friend in '05 with 268k miles. It's still running strong today with over 500k miles on it.
Jamesq87
Alabama
Over 100,500.
Drained 5w20 pennzoil, replaced with 5w20 pennzoil non synthetic high mileage. Replaced filter with fram. (Same as before)
Truck runs great.
meedom
Has anyone had any issues with installing the larger RP 20-870 vs the smaller one on the 5.7? Is it any more effort to get it on, and are there any known benefits?
R.L.K.
Bristol , Tn.
A few members are running it , (Hemi395) is one I remember off hand ....I've heard nothing negative , in fact only positive .
I purchased 2ea & will be installing next time I replace my filter ....maybe someone who's installed the RP20-820 will reply .
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
That will be my next filter, hold alittle more oil and has more filter area .
Can't see a down side on it.
Jared26
Last oil change at 20,000km right on the dot, Pennzoil ultra platinum 5w-20 with a mobil 1 synthetic oil filter for a 2010 ram (bigger filter than the 2013+).
Next oil change will be at 30k and I'll be running an analysis through blackstone on whats in there now.
jettajam1
CA
2012 and 2019
Oil changed at 95332 (8,000 miles between last change)
Out - Redline 5W-30 / Royal Purple 20-820 filter
In - Redline 5W-30 / Royal Purple 20-820 filter
R.L.K.
Bristol , Tn.
Fantastic oil , filter and oil weight choice Sir. !!
Old Fart
Timmins, Ontario
2005 Power Wagon
Any way to get Redline up here in Canada? I've checked Redline's website but only shows US.
1Popeye
