- Apr 28, 2012
- 23,266
- 44,957
- 2010 Hemi Reg Cab 4x4
- Hemi
Let's start a data base of just your oil change and filter no real discussion needed past that unless you feel like sharing it. Conventional or synthetic and/or additives, pressures and temps as seen through EVIC.
Burla's last oil change over 15k miles on the Ram 2010 5.7, 2 year oil change interval, changed filter at 14 month mark.
5w30 Redline
Royal Purple Filter
Out going oil 5w20 Redline
Royal Purple Filter
Oil Pressure 52psi driving 42psi idle.
Engine Oil Temp and Coolant Temp under 200
Tranny Temp 134
This oil worked to rid my engine tic, engine liked both oils.
RMI 25 added to factory coolant yearly.
5w30 Redline
Royal Purple Filter
Royal Purple Filter
Tranny Temp 134
