Gamester
- Jun 23, 2016
- 466
- 111
- 2016
- 5.7L Hemi
Since it's tuned to use it a peak flow then I would be worried because you don't have any buffer anymore. You're running a lot more advance than without it. I'd seriously look at running a slightly larger pulley on the blower and keep the O/D pulley and see where your boosts sits. Ideally 10psi max on the stock pistons if you haven't increased the ring gap.
Yea, I'm probably going to the speed shop for dynoing this weekend and will mention this to them. Maybe we'll have to detune it a bit or something if it is actually hitting that high of PSI. The dyno setup they hook up more accurately reads the pressures, so we'll see what it shows there first.
Thanks
