BBRAM2500
- Jan 3, 2017
- 205
- 65
- stony plain Alberta
- 2016
- 6.7
Id be changing my pcv my air filter if your over 60k miles or 100k km your plugsmake sure your obvious stuff is done first a clogged air filter will screw up milage and a emission test when i use to work as a mechanic in ontario where the e test these were always the first things to check and 90% of the time the problem also if you have a laser temp check both sides of your cat it should be hotter on the outlet side if its not and you dont feel good flow out the tail pipe id be checking that too
