XXSNOTRODXX
Hey guys,
2011 Ram 1500,Sport,4x4,5.7l.
I've had my truck about 6 months now and as far as I can remember I noticed the issue around the time I got it...And It hasn't got any worse I don't think. But it bugs me and I don't want it to one day decide not to start. Trying to see if it is a common issue with these truck and/or if anyone else has/had this issue and knows a fix.
Roughly about 9 times out of 10 the truck fires right up when you crank the truck over...no problems. When the truck is running it runs great. no check engine lights or anything like that either.
But the other 10% of the time is what concerns me. It doesn't seems to matter if it is cold or hot...it can do it the first start of the day or after parking at a store for 5 minutes and taking back off. Put the key in the ignition,turn to crank position and it just cranks and cranks and cranks and cranks for a good 10 seconds or so before it finally fires up.
A little embarrassing when a truck this expensive struggles to start at times ...not to mention a worrisome issue reliability wise.
If anyone has an idea.. feel free to chime in. thanks!
