Rear differential
Jarebear93
Houston
When I got an oil change the dealership told me I need my rear differential serviced. My 2013 ram express has 60k miles. Just want to make sure I really need that serviced or not. If so what about the front as well?
kevperro
Pentastar 3.6L
I would say for once, the dealer isn't ******** you. It is easy to change by yourself and you will save some coin.
mohemipar
Michigan
2017 Laramie
6.4 Hemi, 4.10's
When in doubt always check your owners manual maintenance schedule.
Jeepwalker
WI
2012 Reg Cab, 4x4
I change my own diff lubes on my vehicles and do it more frequently than 60k. They use a synthetic lube from the factory so 60k sounds about right. If you did it at 30k it wouldn't hurt either.
meedom
So easy to do, grab some full synthetic 75W140 and just do it!
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I like to do the rear about every 75,000 & front about 100,000. The more you tow the lower those numbers should go down. I am sure there are many trucks out there that have never been changed but as most have mentioned, for as easy/cheap as it is to do... why not.
Tach_tech
5.7L HEMI
If you have a limited slip yes you do.
homeguy
Calgary AB
2013 Big Horn
I change the rear every 40k and the front 60k
meedom
Yes, if you want to get over-the-counter both mobile one full synthetic And royal purple full Synthetic have it already added.
