808ram1500
- Mar 5, 2017
- 434
- 89
- Big Island, Hawaii
- 2011
- 4.7L
i have a 2011 Ram 1500 quad cab with a 4.7 motor 3.55 rear axle ratio, was planning to put 37's on the truck as its lifted 6 suspension 2 body. i emailed moes performance and heres what i was told.
I would go all the way to 4.56's with the 37's. Even with stock height tires, the 4.7 trucks see a huge gain from running a 4.56 gear.
Thank you.
Matt Fikac
does that seem about right? i have 205mm (8.07") HD front axle and 235mm (9.25") rear axle
do i order these gears?
Front:
Motive 4.56 ration Front ring and pinion gear set for Dodge Ram 4x4s. This is for the 8.0" front differential.
For the rear what is a ZF axle and non ZF axle????
Rear:
These?
Motive 4.56 Gears for 9.25" Rear
Or these?
Moe's Performance 4.56 Gears for 9.25 and 9.25ZF Rear
Thank you.
Matt Fikac
Front:
Rear:
These?
Or these?
