All depends on how you use it! Is it a commuter truck or do you tow haul? Drive it on beat up roads?
Are those containers for both difs?
Wow ! That old oil looks black . How many miles on it ?
The photo of your old oil is about what I got out of my front diff alone .....
If I remember correctly I got about 1.6 qt in the front , and about 2.5 qts out of the rear .
If I was you with 35s I'd be changing every 30k or less with RP oil.
Here's a link to when I did my differentials fluids change .
Differential oil change - DODGE RAM FORUM - Dodge Truck Forums
Hope this helps !
A lot of folks don't know this but the recommended interval for difs is like 20k miles, you are using group 3 oil like you chose, I say 30k. Here's the rub, no offense and I encourage you to do your own research, but your fluid choice for the difs was probably the worst one you can make. RP consistently tests at rock bottom with lucas for difs. In many 4x4 forums, RP diff fluid is practically a swear word. The problem is, gears are the one application where you have no internal cooling features like you do with the tranny and engine. Even though there isn't combustion adding acid like the engine, the temperatures can easily get high, especially in sand. You can use a temp gun to check, anything over 240 degrees F and you are taxing any base oil not group 5, IE esters. Gimmick oils die quick in this application, it's just a fact.
An ester based fluid can easily triple you interval, even oil stop says it doubles the life of the oil in the diffs. Ester based they sell and recommend is Redline. As another decent option is Amsoil gear fluid, widely believed to use a combo of base fluids. Esters don't break down under heat and load like mineral oils. I have posted many things on gear fluids in the beginning pages of the syn thread, I posted some of the testing and white paper as well I do believe.
Must read this.
Now the downsides of these have long been corrected through time tested formulations. There are basically two oils that you can get otc that give you these benefits of esters, Redline and Motul. It is widely thought Amsoil is a sturdy oil and they use some esters, but nowhere the commitment to esters as Motul and Redline.
So from link this...
Synthetic oils have better resistance to aging and high temperatures and a longer service life than mineral oils. Depending on the base oil (SHC or PAG), the oil change intervals may be three to five times longer at the same operating temperature.
Approximate oil change intervals of gear oils at an operating temperature of 176°F (80°C) are:
Mineral oil: 5,000 operating hours
SHC oil: 15,000 operating hours (extension factor 3)
PAG oil: 25,000 operating hours (extension factor 5)
So according to machinelube.com and only a fool would argue against that, Redline would last a factor of 5 against Royal Purple or any mineral based oil as far as interval goes. So go 20k miles and keep your fingers crossed, and next time Redline your diffs up, and go 100k on it.
I honestly feel RL & Amsoil SVG are the top performers in gear oils!
JMHO!
