Running of ecutout wires
09SMOKINHEMI
TEXAS
So I'm a little confused/worried on where to run the wires for my cutout so that they're not so close to the exhaust or headers. Don't want the wiring to melt. How did you guys run the wiring to avoid this issue?
sent from my Samsung Galaxy S3
4x4Hemi
Edmonton, Alberta
i just ran mine up and ziptied it to the frame. and then along the from, over top of the power steering pump and then to the battery and such.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Frame rails are your friend like mentioned. There are usually small holes drilled in all the brackets that are welded to the frame. These make great places to run wires through, or put zip ties through to keep the wires away from the exhaust.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Awesome thanks guys
TNhemi12
Take some pics as I'm interested in doing this as well, just worried that I've seen some people having problems recently.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Yea I've read some of those threads. What gives me some relief is that most say raceland provides excellent customer service
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Like Trup said get some cover for the wires and make sure the ends are good and can keep dry far as no water getting in or corroding.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Ok here's what I ended up doing. With my longtubes and y-pipe and cutout after the 'y' the cutout ended up really close to where the jack is under my passenger seat. Didn't have to run much wire outside at all. Most of it I ran inside the cab. Here's a few pics I snapped of the wires coming out of the cutout then over the heat shield then through the plug under the jack.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
good spot there
