S&B intake
I'll have to agree with the above poster and his review is spot on.
Although I'll touch base on a few things:
The plexiglass cover does fit correctly if installed properly. "Star pattern" tightening is required as long as it's not over tightened. It WILL bow if tighten too much.
At least, this is from MY kit and three others I've installed/seen.
The rubber gaskets should be Just pinched and not flattened.
The sound, where it is not a night and day difference, it brings the surround sound of Hemi and your exhaust together whereas before it was either heard from the front or the rear when throttle was applied. The sound is really noticeable after 3500 and more at part throttle/under load. Not obnoxious at all, just right.
The performance increase is worth noticing if you are realistic. Not going to be earth shattering but just enough extra kick to feel it and smooth out those little "rough" spots from before.
As far as gas mileage. It's subjective and too many factors affect it. I have a 16 Ram a Sport CC with 3.92s and I live in Missouri; 89 oct and mostly city driving. I get about out 16.5-17. I driving somewhat spirited but casual normally. Since I've added the S&B, catch can and my black widow 300 muffler I went from 15.2-15.5 to 16.5-17. Same driving habits, location and fuel.
So take it with a grain of salt.
The quality is great, a true definition of the meaning, you get what you pay for.
Hope this helps.
EDIT: some advice, put some blue thread locker on the bolts that secure the lid down.
Sent from my iPhone 7+
