Standard throttle body size
Jwithing
STL
Anybody know the stock TB size? Just recently bought my truck and found it had a cai and catchcan. The TB looks ported to me, so I measured it with digital calipers at just over 83mm. Was going to get a Moe's 87mm, but not sure if it's worth it now?
BeanRAM
Wisconsin
Hard to tell from that picture, get us a better one with better lighting
Jwithing
Jwithing
STL
Haha, sorry,uploaded the wrong one. This one probably isn't much better, but that's all I snapped when I was in there. Forgot to snap another one when I took it back off to measure with the calipers :slap: . If need be, I'll pull it back off tomorrow to get better lighting.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
The new throttle body, standing alone, will probably not make a significant difference in your performance. If you also add a aftermarket exhaust, a CAI and a tuner with a custom tune to your new throttle body you will notice an increase in the performance in your truck.
Jay
Marciel
I have a Moes 87 mm throttle body, I did it at the same time as my grannetelli hot street coil packs but they did make a noticable difference.
Sent from my VS835 using Tapatalk
Jwithing
Jwithing
STL
Jay
Got the vararam installed, 180 thermo is on the workbench, PCM swapped tonight w/ hemifever tune on the way, and currently figuring out which route I wanna go for LT headers.:crazy:
Jwithing
Jwithing
STL
I'm surprised to not find any aftermarket intake manifolds. Do these come with the eagle intake manifold? My previous vehicle was a 2011 300C, I know the eagle intake manifold was something that came later stock to squeeze a few more ponies outta the hemi.
Marciel
Hughes has a hemi intake manifold it's like 800$ or something crazy.
Jwithing
Jwithing
STL
Yeah? What are the claims? I know when the eagle intake manifold came out, people were jumping on them for $1200 just for 15 HP. It was stock design in 2013+ I believe. But keep in mind, I believe a cam wasn't available at that point lol
Marciel
I don't even remember what brand it was, I just remembered it cost twice as much as one for my 5.9 lol.
Bobbo
Los Angeles, CA
The intake manifold is different between the trucks and the cars. The truck manifold is taller and is an "active" intake.
Jwithing
Jwithing
STL
Oooh, careful... Start using word like active, you're gonna get me all excited
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
You got all the goodies(well a lot of them). You should see a marked increase in performance. The headers will also give you a pretty good boost also. What gears do you have? You might check with Matt at Moe's Performance about the intake.
Jay
Jwithing
Jwithing
STL
you got all the goodies(well a lot of them). You should see a marked increase in performance. The headers will also give you a pretty good boost also. What gears do you have? You might check with matt at moe's performance about the intake.
Jay
3.92
