If you want to KNOW if you need "bigger" injectors , You can use the dataloggin feature of Diablo products to do so. Run a log at WOT, under the most demanding conditions that you drive. select the IPW pid( Injector Pulse Width) and RPMs at a given point in the log( while playing back the log, just pause it and use the slide bar to get the numbers.
Plug those numbers into this site
Stealth 316 - Injector Duty Cycle Calculation
and you'll get the IDC, ( Injector Duty Cycle)...If it comes out to close to 100% you may need Bigger injectors, if your over 100% you definatly need them
I created an xcel doc with the math in it so I could plug a bunch of numbers in it. If anyone is intersetd PM me.
I know ths doesnt answer your question completely, but I thought you might find this useful....and if your building over time you can better figure out when you will need bigger injecotors, as from a budetary point there is also the fact that the tune has to be scaled.
Hope this helps
