Sudden loss of 2-3 MPG?
Gamester
So I usually can get around 17-18 MPG in my supercharged hemi. However, for some reason a few weeks back when we had our first really cold below 0 day, I suddenly now only get 15MPG. The temperature has since warmed up and it is still only getting 15MPG consistently. I'm at about 19,000 miles right now and haven't had any issues and there is no noticeable loss in power or anything so I'm not sure why it dropped. Any thoughts?
stimpy433
IOWA
Winter blend gas, I know I always lose some MPG once they start selling it. My MPG goes back to normal once the summer blend gas comes back.
huntergreen
different gas from a different fill station?
Gamester
Gamester
Same gas station I always use, but I wasn't aware there was any change in fuel during the winter months; maybe it is something like that.
huntergreen
dont know where you are, but in nj, the change to winter formula occurs sometime in october.
SyN
6.7L CTD Owner
Tornado Alley
2017 4WD - Tow Prep Pkg - Off-Road Pkg - 3:42s w/Anti-Slip
6.7L CTD
I agree with stimpy! I wouldn't concern yourself too much with it. Yes it does SUK but there really is nothing you can do to change it.
I don't think there are any fuel additives to help boost the mpg even in the slightest.
Just drive as civilized as you can.
Gamester
Gamester
Lol, I wouldn't have a supercharger if that was a possibility :Big Laugh:
Yea I guess I will give it a month or two and see if it gets better or not. If I start seeing changes in performance I will look further into it at that point.
Thanks
Johnnymac2k6
Ohio
2007 Ram 1500
this is correct, and this is why your mileage went down. period. I easily lose 1-3 MPG during winter months. winter blend gas, plus more dense cold air with longer warm up periods for the engine, so a richer running engine, etc.
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
I agree it's just the winter blends. I'm down about 3-4 mpg with my truck because of the gas and idle time.
Gamester
Gamester
I didn't think the idle time was factored into the MPG gauge, but if so that would certainly explain it alone since on really cold days I usually do 10 min of warm up time at home and work as well.
Thanks guys
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
I personally during the summer months try never to let my 5.7L idle for more then 2 min.
Winter months 4 min is tops. Then attempt to drive slow for at least 5 blocks to let the trans/Rearend oil turning enough to get every moving part proper lubrication.
Just not a huge idle fan since this is where most fuel dilution occurs as well as lowest Oil psi.
Blackout15
NJ
You might want to check your tire pressure too, I know I lost a few lbs. in all 4 corners when we got our first cold spell. It may not be much but it doesn't help MPG at all. Also as stated winter blend gas isn't helping at all either.
novelmike
Central California
I've watched my MPG gauge move while I'm siting in my truck at work. I'm either waiting with the a/c or heater on, depending on what time of year it is. So idle time is most definitely factored in.
MEchase
Newport News, VA
Does everybody get winter blends or is this something usually reserved for colder/northern areas?
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
My understanding is everybody eventually gets it but some colder regions will get the winter blend sooner.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
In Western NY we get the winter blend sometime in October and it switches back to summer blend sometime around May.
gofishn
Iowa
hemi 5.7L, 345 cu in
Regarding Winter fuel blend:
Everyone eventually gets it, simply put, there are not that many different pipelines pumping gas, from the refineries, all across America.
As regards the OP mileage, it's the Thanksgiving and Christmas dinners.
You just ate too much, the truck is now hauling much more of a load and your gas mileage went down.
Lay off the Brach's Chocolate covered cherries.
... and get to the gym. Your overworking that Hemi.
Gamester
Gamester
or maybe it's from the weight of the extra muscle gained from the gym; ever thing of that? :naughty:
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I agree with Winter Gas causing the drop.. It happens every winter for me in Maine
gofishn
Iowa
Nope. I can honestly state I would have never thought of the Gym.
Not for the last 30+ years.
