Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 233 8.4%
  • Royal Purple
    Votes: 325 11.7%
  • AMSOil
    Votes: 396 14.3%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 992 35.9%
  • Other
    Votes: 660 23.9%
  • Total voters
    2,766
R.L.K.
Bristol , Tn.
That's what she said
R.L.K.
Bristol , Tn.
Seriously...... right when i changed my avatar.......
LoL
Ha ha ha ! Perfect timing
SyN
6.7L CTD Owner
Tornado Alley
2017 4WD - Tow Prep Pkg - Off-Road Pkg - 3:42s w/Anti-Slip
6.7L CTD
All of you who begin using the larger filter:--->Can you record your PSI with the smaller filter?
Then with the larger filter.
Examples
1. Cold Start up
2. Idle psi @ operating temp in park
3. Idle psi @ operating temp in drive with brake in
4. Cruising @ operating temp between 60-70 mph.
A few have recorded a slight psi drop.
I know the Larger filter for the FU XG2
R.L.K.
Bristol , Tn.
Examples
1. Cold Start up
My plan exactly
Hemi395
Cape Cod MA
I didn't take any before and after pics but going from 6qts PUP 0w40 and 1qt 5w30 with a Wix XP 57060 (smaller size filter) to 7 qts RL 5w30 and a RP 20-820 (larger size filter) I see no appreciable difference in oil pressure. If its any different, its 1-2psi lower at most.
Burla
2010 Hemi Reg Cab 4x4
I should probably know this, but which one is bigger 20-820 or 10-48? And you can use the larger one on the later years right?
Ramnewbie
For the (Elderly-Senior Citizen) crowd: Pennzoil Created a Very Robust Re-Energizing Sunshine Yellow!
Notice the HM...
Loaded with Testosterone & ****** with just a pinch of HGH!
This is not just your everyday Voooo Doooo! This is a special blend of Voooo Doooo... Use with extreme caution! It causes a few items to Swell which prevents leakage!
Amazing Brilliant Colors --->Don't you think?
Not to mention the Totally Re-Engineered Gulp Free 5Qt Jug!
16 Finely Tuned Engineers from the Voooo Doooo Accademy worked many years perfecting this design. Isn't she a Beaut!
Molded Perfectly for the Smallest (Sensitive) hands to the largest rough & callused hands.
You forgot the optional Rogain
Ramnewbie
Notice the HM...
You forgot the optional Rogain [emoji3]
R.L.K.
Bristol , Tn.
Yep the RP 20-820 is the larger filter ,and yes it fits just fine with the 2013+ models with the electronic steering actuator.
I'll post a picture of both side by side in a few minutes. ..
RP 10-48
RP 20-820
Bonus pic!
Not bad shots from 50 yards
AFMoulton
Nuevo Mexico
RP 10-48
RP 20-820
Bonus pic!
You have the 20-820 installed? Could I see that pic[emoji6]
R.L.K.
Bristol , Tn.
I don't have the RP 20-820 installed yet .
I think Hemi does , or has in the past ?
R.L.K.
Bristol , Tn.
R.L.K. that's an impressive Redline stash!
Between my 3 ea vehicles , I use about 11 gals per year .... I have more than the photo , I believe I have 12 ea qts of 5W-30 & I also have 13 qts of 10W-30 coming in the mail
Hemi395
Cape Cod MA
I have one on now. No difference I can tell, I just like the idea of a larger filter
R.L.K.
Bristol , Tn.
Can ya post a pic of it installed Sir ?
U&A
Michigan
2016 3500 SRW
6.4 HEMI
A guy at my work with a 2003 ram 3500 with the cummins just told me his current OCI is 20,000 on Rotella 15w40 .... thats CONVENTIONAL!!!
wow!
R.L.K.
Bristol , Tn.
Not much meat on those......
You DID kill em' though.
From 50 yards still has enough Kinetic Energy to travel completely through a Brand New Block target .
Not bad , that's enough to complete a pass through on two live deer unless you hit the shoulder bone
The Bow is a PSE EVO MAX with 80 lb limbs & set @ 80 lbs . Shooting @ 306 fps .
Arrows are Easton FMJ with 100 grain field points total arrow weight 546 grains c08ac668c34555b6b1bf86083ebdc43a.jpg
VLG6963
