just bought 5 qts. redline 5w20 and RP filter for $94 from summit
More than Likely you know this, but just in case you are short a few quarts.
Well you know what I use, but I'm not 100% sure Ultra is group 3. In fact, if ultra is group 3 then it is the best group 3 on the market IMO, it is the only oil I ever seen to have group 5 noack numbers, meaning the stuff simply does not evaporate. I "believe" ultra is group 4 or have some group 4 or 5 mixed with group 3, or it has one hell of a viscosity index improver! Don't know for sure, but Penzoil has put all it's chips into the platinum bucket even though ultra is a better oil. I believe they do so because platinum is group 3 and is cheaper to make and still very high quality compared to other oils. If you are not getting the knock with ultra and you are happy with it, I would stay with it. Ultra is considerably better the platinum for the hemi, and if I wasn't running redline it would be what I would try next maybe equal to Amsoil on a shorter oil change interval. Now, if you are looking at 15k oil change intervals or your Hemi starts ticking like your neighbors, let's get you in redline but if you change your oil in the less then 10k mile range, Ultra is great great stuff.
On a side note, why don't you talk to your neighbor and just give him a friendly tip? Sounds like his truck needs to be introduced to my favorite girl, Molly.
Edit, I found this on Ultra, seams like mostly group 3 but they do use group 4 too. Anyhow, over on the oil forum I don't think an oil on the mass market has a more loyal following, oil guys love penzoil Ultra!! Do a search on Ultra and cleaning, this stuff keeps your engine clean and cleans up old varnish as well.
jeesh , ya sure it's a tick and not a rap!,lol.thank you sir. i will stick with my ULTRA , yeah maby il speak to the neighbor. but hes one of thise headstrong old school guys who says oil is oil and the hemi's always had a "tick" il try to show him the difference vs mine in the morning cold starts. but hes so head strong as far as im concerned he can keep his little drummer boy tappin away all christmass lol, poor ram
Bump for a good article I found, when they talk about PAG or glycol it is another term for what I've described previously as group 5 oil, or better known as Redline or Motul.
Machine Lubrication .com Which Synthetic Lubricant is Superior?
From text In the temperature range of 70 to 90 degrees C, there is only a 5-percent difference between the EHL film thickness of mineral and PAO lubricants. In this same temperature range, a PAG lubricant gives thicker films ranging from 16 percent to 37 percent thicker than mineral oil.
So if you read the entire article it would appear that dino oil has slightly better film strength at lower temps, however they offer no protection when the oil is not there. That is why most oil companies use moly anyway, for when the oil is not present. But I wanted you guys to see how much better group 5 is at operating temps, this website says, "a PAG lubricant gives thicker films ranging from 16 percent to 37 percent thicker than mineral oil." This is at car operating temps between 200 and 250 degrees F. This means when you are at operating temps your engine has around 30% more lubricity and film strength then any other oil, even your group 4s.
Uh, another reason for the lighter oil, is the mds system, (4 cylinders running instead of 8). I heard it (the mds) does not like to use the 30 an up oil......just what I heard from a dodge tech.......Your Welcome, as I stated before there always is an argument for "is it necessary to use high quality oils in a combustion engine". I personally "believe" because we use a thin oil there is, it is less important in cars running 30 weight. The good part of that info is it tells why, if you have a thin oil you definitely want the film to be as thick and strong as possible, and by using group 5 your will accomplish that by 16 to 37 percent. There is another way to make 5w20 have great film strength, by switching it to 10w40 or other thicker oils, but unfortunately we cannot do this in our Rams.
Another link from that website, basically summing up what was already covered in this thread but it goes into the history of synthetics. The Basics of Synthetic Oil Technology
When they talk about synthetics here, they are only talking about group 4 and 5. from text, There are two American Petroleum Institute (API) base oil categories that include synthetics- group iV and V. So when you read the benefit chart it is group 4 and 5.
This is from my 2014 owners manual.
NOTE: MOPAR® SAE 5W-30 engine oil approved to
Chrysler Material Standard MS-6395 may be used when
SAE 5W-20 engine oil meeting MS-6395 is not available.
I guess this dispels the myth that 5W-30 is somehow bad for MDS systems……….
whaddyI say,...''msd''?? lol.....I need a break....This is from my 2014 owners manual. I'll probably just try to follow this:
Engine Oil Viscosity — 3.6L/5.7L Engines (1500
Models Only)
MOPAR® SAE 5W-20 engine oil approved to Chrysler
Material Standard MS-6395 or equivalent Pennzoil® or
Shell Helix® is recommended for all operating temperatures.
This engine oil improves low temperature starting
and vehicle fuel economy.
There is a description letter from Chrysler about their oil standard in this thread:
Chrysler MS-6395 | Passenger Car Motor Oil (PCMO) - Gasoline Cars/Pickups/Vans/SUVs | Bob Is The Oil Guy
