- Apr 28, 2012
- 23,241
- 44,874
- 2010 Hemi Reg Cab 4x4
- Hemi
The importance of using good-quality oil in an engine cannot be overstated. AMSOIL synthetic motor oils consistently outperform conventional and other synthetic oils in virtually every category of performance, including wear protection, extreme high- and low-temperature performance, foam control, viscosity retention, rust and corrosion protection, volatility and fuel economy. While other brands may provide good performance in some of these areas, AMSOIL synthetic motor oils consistently perform at the top in every category. Drivers can have confidence knowing that AMSOIL synthetic motor oils provide maximum performance and protection.
Every new engine I change out at 1500-3000 then run AMSOIL. Amsoil is the only Synthetic motor oil in the industy with a "Guaranteed" 25,000 mile / 1yr drain interval.
I am an Independent Dealer for Amsoil. I run it in everything I have.
Two one post shills in a row, I guess we know which oil company has the best marketing teams.
