Nutshell
- Feb 4, 2014
- 658
- 471
- 2020
- 5.7 HEMI
You should email them and see what response they give, post it up when you get it.
I already did. I'll need to send them the pic tomorrow.
Neither my royal purple or puroilator are like that, and I have 4 filters total. I don't know what is going on with that. I wonder if AE filters are made at the same place Champion labs and if they have been poutting these out for a long time. I still say that isn't right, unless there is a redesign that allows something other then that rubber ring to hold the oil in the line.
I think you uncovered a massive defect across a lot of brands unless I hear a good excuse for that. Same ZZ on the face plate, I think it was made at the same place. I couldn't get a damn clear pic, but you can see none of the older filters have a gap. Hard to see but my RP oil filters have the same ZZ on the face plate.
Time for some research, like I said good catch. I googled "champion labs oil filter drainback valve" and 100's of pics all look like mine, unless they have no drainback valve. I still say that aint normal. Either way Amsoil is forgiven, it looks like a Champion labs cluster fawk.
I have the strap kind and I use a piece of rubber to grip it better. Not the easiest filter to get to but definitely not the worst...
Yeah 7 quarts.Thanks ! Yeah I've seen worse lol but it does look tight but at least you can see it . These hemi's need 7 quarts plus what ever the filter holds if I remember correctly from the owners manual ?
Yeah 7 quarts.
Oh what type of oil filter wrenches are you guys using the caps that fit on the end of the filter or the traditional loop type on the 15 ram 4x4 hemi's ?
Was looking at it and looks pretty tight under there .
You only need to do it once, and you can just hand tighten after that. Really no need to cinch it down really tight, I've never had one come loose and do it by hand every time, on and off.
Yeah, I only hand tighten mine, and I always back it off a smidge when I tighten it. I would look at the RP filter before buying it, make sure the purple silicone fills all the gaps in the holes.
Cool thanks great idea just got one ready to go . Did you mean to slide the bag over the filter because of angle of the filter when removing it so it doesn't pour everywhere ?Use a quart plastic bag when you start to see the oil drip over the filter, then put the bag off and twist the filter off, and hold it in place for a minute. Catches almost all of the oil.
