I've had better engine performance bar none since using synthetic blend. I notice a lag in horsepower without it. I mix my own potion 60/40Personal Preference based on what? Science or marketing? I keep an open mind, sell us on why a blend is a good option.
Big Advantages? None! Maybe 2 or 3 at the most {Slight} advantages...
1. Cold Start Pumpability can be better.
2. Capability of extending your OCI out to 15K miles or more.
3. Possibly better heat handling capability.
4. Some will say an advantage in Cleaning Capability but there has been Oh So many documented statements and pictures of conventional oils being used with 200K-400K miles on motors and during tear downs parts were found to be virtually spotless...But these were documented with PROPER OCI being kept during all these miles...
Todays Conventional and Semi-Synthetic oils are Outstanding! An owner has to take into consideration Engine Design and Driving Style and Habits... As well as the Climate the auto is going to be exposed to 24/7...
Do you want to stay within the OLM-->5K-8K miles? or Extend out to 10K-15K miles?
Use whatever makes You get that Warm Fuzzy Feeling inside once the New Filter is screwed on and the Fresh Oil is poured in...
Search and find a Top Name Brand oil with a Good Amount of Moly and Zinc! Don't neglect that Air Filter nor your OCI...
Not to be noisy! But what brands are U considering?
What would be the advantages or reasons for using synthetic blend vs group 3 full synthetic?
