Don't waste your time unless you're going to port it as a way to run nitrous.
If you have a 2013 RAM you have a 5.7L Hemi and not a 5.9L Magnum.
Throttle Body (TB) Spacers date back to the days of carbureted engines, where a little space allowed a better fuel air mixture--supposedly.
With fuel injection, and your RAM is fuel injected, there is no fuel air mixture at the Throttle Body, only air and maybe some blow by from your PCV.
Even on a non-direct injected engine, any swirl imparted to the air is useless by the time it reaches the intake valves.
A ported TB on the other hand is different in that it has been machined to have a greater diameter at wide open throttle, but remain stock at lower air demand so that tuning is not needed. Of course you have to have something else on the engine to use that air, like long tube headers or racing camshaft.
I personally question the ethics of any vendor manufacturing or still selling these paperweights for fuel injected engines..
