Tick and mIsfire?
Trucker202
I have a 2011 outdoorsman with the 5.7. I know it had a broken manifold bolt on the passenger side. I now have a tick on the drivers side and a misfire on cylinder 3 (p0303). It runs fine just cruising and under light acceleration. If I get over 3k on the tach it starts misfiring and throwing the code. I have religiously changed the plugs every 30,000 with oem ngk's from the dealer. Always run premium fuel 93 octane and always changed oil with 5w-20 Mobil 1 full synthetic. I just changed the plugs again and replaced the number 3 coil. Also did a compression test and have 195-210 on all cylinders. Still have the issue. Where could my problem be?
Burla
2010 Hemi Reg Cab 4x4
You have good air filter? You say good gas but about about octane? Still original ignition? Clogged injectors, bad fuel filter.
Here is a ton of stuff past what my pay grade tells me to check, check out scoping the misfire.
Trucker202
Trucker202
By premium fuel I mean 93 octane. It has a cold air intake with k and n filter.
