Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
Time For A Change
This is a discussion on Time For A Change within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
Someday I want to join you in the CTD fun with an Aisin though. I can't fit my family in ...
Like Tree24Likes
Sponsored By: Moe's Performance
Reply
Old 07-03-2017, 02:00 AM   #21 (permalink)
smiley3303's Avatar
Super Moderator
Ram Year: 2009 Ram 1500 Laramie Crew 4WD
Engine: Hemi 5.7L
Default
Someday I want to join you in the CTD fun with an Aisin though. I can't fit my family in a truck anymore so was considering a Diesel Suburban maybe I can put Ram heads on it to pretend Ram makes a big SUV for me.
Sponsored Ad
Register to remove this ad.
__________________
smiley3303 is offline   Reply With Quote
Old 07-03-2017, 02:56 AM   #22 (permalink)
Ratket's Avatar
Ram Year: 2014 2500
Engine: Hemi 6.4
Default
So what did all that cost you? "Ball park" is good enough-
__________________
2014 Ram 2500 mega cab Big Horn 6.4 4x4 3.73's Factory 20's wrapped in a 33" maximum steel/ Factory cab length running boards/ UnderCover Flex Tonneau cover/de badged/tinted over factory tint.
Ratket is offline   Reply With Quote
Old 07-03-2017, 09:44 AM   #23 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Default
LOL
They used to make diesel powered Suburbans back in the day. I bet you could do a Cummins swap and then you can tell the wife you got the family a hybrid.
smiley3303 likes this.
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is offline   Reply With Quote
Old 07-03-2017, 09:59 AM   #24 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
It depends on whether you do any of the work or not.
A full delete, with a cold air intake, tuning & software, egr delete, throttle valve delete, cat delete, straight pipes, big black tip at the back...with all labor performed by a shop would be right at $2800 - $3000.
Add the Edge CTS 2 programmer/configurable display + $450
Someone with good computer skills, some wiring savvy and with a full set of tools can reduce their price by $550 - $600.
Given the little bit I've driven the truck since the work was complete I can honestly say it's worth it.
A couple of optional items to consider would include the BD Diesel 68RFE valve body upgrade and a deeper transmission pan. Flowing more fluid at higher pressures will keep those clutches from overheating, slipping and failing.
Oh...beware the 120 HP tune which I've decided to call the "HolyPhuck!" tune.
smiley3303, DRkNESS and BossHogg like this.
__________________
MICHAEL
SUPER MODERATOR
Old 07-06-2017, 11:13 AM   #25 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
I hit 38 psi yesterday afternoon on the 80 HP tune (Tune #3) and I had no idea my truck could move like that.
I need to back off a bit until that BD kit goes in the transmission! LOL
__________________
MICHAEL
SUPER MODERATOR
Old 07-06-2017, 12:37 PM   #26 (permalink)
Stangshcky12's Avatar
Super Moderator
Ram Year: 2007
Engine: 5.9 Cummins
Default
I wouldnt make a habit of going over 38 psi that often, your headstuds wont like it and anything over that is really over the stock turbos efficiency.
__________________
RamForum.com Moderator
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Stangshcky12 is offline   Reply With Quote
Old 07-06-2017, 12:55 PM   #27 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
Oh, you got that right, Cody.
I'm gonna be talkin' to the shop later today because I firmly believe I need a few more upgrades to help keep this thing in one piece!
__________________
MICHAEL
SUPER MODERATOR
Old 07-06-2017, 01:02 PM   #28 (permalink)
SwollenMonkey16's Avatar
Ram Year: 2017
Engine: 6.4
Default
Ha ha domino effect. One upgrade turns into another and another. Sounds like your truck is gonna be a monster when your done with it. If I had a CTD I would definitely do this also. My bro has one and his check engine light has came on several times before 30k for DEF system crap.
__________________
2017 RAM 2500 Tradesman 6.4L CCLB 4x4
RC Level; 20x12s; 305s
SwollenMonkey16 is offline   Reply With Quote
Old 07-06-2017, 02:16 PM   #29 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
I had 5 CELs in 5200 miles. Once it went into limp mode, leaving me by the side of the freeway in a very rural area. I was not happy at that point.
__________________
MICHAEL
SUPER MODERATOR
Old 07-06-2017, 04:01 PM   #30 (permalink)
69GWC's Avatar
Ram Year: 2016 Ram Express QC
Engine: 5.7 Hemi, 8sp
Default
Throw a s.465 turbo and 2nd gen kit on there and you will see 50psi boost easy.
Do miss my 6.7 it was a beast..
__________________
2016 HD 1500 Delmonico Red Express QC, 4x4, 5.7L Hemi , 8sp,
Tinted windows ,Carven Progressive, Bilsteins at 2.8 in the front, rear TTC-1211s , Bilstein shocks , Hellwig sway bar & Timber Grove air bags ,Catch can, Husky liners, ATC- LES Topper .
2016 Harley Davidson Low Rider, 103 H.O. , PCV Tuner Rinehart exhaust.
69GWC is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oil change time! PassivAggressor Engine & Performance 28 11-11-2016 11:20 PM
First Time Doing An Oil Change adrianp89 Engine & Performance 13 03-15-2016 01:10 PM
Time for an oil change FancyStancy Engine & Performance 9 02-18-2014 09:47 PM
Time For A Change MOPAR78 General Discussions 8 07-25-2010 02:42 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
