jojo750
ran into an issue a few months ago, and wanted to ask if anyone else had seen this problem. it has been fixed. but wanted to check in. this all happened around halloween, and thank god for my extended warranty.
came out one morning, and my truck battery was dead. got it jumped and went to work. got off work, and the battery was dead again. got a jump and stopped at the auto zone by my house to let them check the battery. they said it was the alternator not charging properly.. no problem. extended warranty will cover that.. when i got home. i cut the truck off and was walking into the house when i hear a humming noise...
call a neighbor around the corner who works at the dealer i go to, he comes over and says that its the fuel pump.. opens the fuse box, pulls the fuse. and says to put the fuse back in the morning to start it..
next morning, i drop off at the dealer, explain whats going on...
took a few days to get the part in, but ended being a bad fuse pump relay. to the dealer had to replace the TIPM.
anyone else had this issue?
i have a 2011 ram with 53k miles on it (had 47k at the time of the failure).
