93 Octane Performance Tune
This tune is designed for use with premium fuel. The Performance Tune (or ?Diablo Tune? as it?s called in some vehicles) will unleash the maximum available Horsepower, Torque and Economy out of your stock vehicle with no other mods necessary! Vehicles will see a power across the entire RPM range with the greatest gains down low. Vehicle will also see improvements in drivability, throttle response, and economy. 30HP 35TQ
91 Octane Performance Tune
This tune is very similar to the Performance tune for 93 Octane but optimized for 91 Octane Premium Fuel. Vehicles will see a power across the entire RPM range with the greatest gains down low. Vehicle will also see improvements in drivability, throttle response, and economy. 28HP 33TQ
87 Octane Performance Tune
This tune is designed for use with 87 octane gasoline. It will increase HP, TQ and Fuel Economy without the need to run premium fuel in the vehicle. While HP Gains are not as great as in the 93 octane Diablotune, this tune wakes up your vehicle?s throttle response, power, and improves overall driveability. 18HP 20TQ
Mileage Booster
The Mileage Booster tune optimizes efficiency for daily use. Horsepower gains will be minimal, but mileage will improve by up to 3 MPG in some applications! Compatible with fuel that is 87 octane or greater.
Modified Stock
This tune is designed to work with a stock vehicle and keep the stock HP and TQ ratings. Use this tune to have factory drivability but modify the parameters of your vehicle's calibration such as speed limiters, rev limiters, tire size and more.
