Murphy Slaw
- Oct 7, 2016
- 1,541
- 2,822
- Southern Illinois
- 2016 Bighorn 4X4 Crew
- 5.7
That's enough....
Awesome data thank you for posting! If you do another trip in the future with MDS disabled please post here again.After reading this thread, I turned MDS off (using the paddle gear selectors) and just returned from a 355 mile round trip for the weekend. I was amazed to see that with MDS off I also experienced a ~ 2 mpg improvement. That's hand calculated. My driving was consistent to previous trips. On the trips with MDS normally engaged, the absolute best I ever saw was 20.2 mpg on one trip leg when I kept speeds to 65mph. Driving normally (for me) with speeds between 70 and 75 sometimes a bit over, and not babying the throttle when passing, I usually would see high 18's and low 19's in miles per gallon.
On the first leg (175 miles) I got 20.95 mpg which was hand calculated, and on the return leg I got 20.68 mpg, driving the same way.
I was very surprised but I'm not complaining.
Another thing I noticed was my transmission temperatures were 3 to 5 degrees cooler with MDS off during the hiway driving, something I clearly don't understand. With MDS on, my trans temps usually are in the 186 to 188 degree range just about all the time. With MDS off, those temps were in the 180 to 182 degree range. I hope this is just a fluke as I can't envision any connection.
Is it better to use tow/haul or run through the gears on the column?
