Any benefit to towing with these sway bars? I tow a 27' travel trailer. Always looking for a more stable ride.
That is the main reason why I put one on my 2015. My 2015 gets driven easy and doesnt see any racing or aggressive driving around town...Its simply used to haul the family around and tow my regular cab to the track and back. With the Hellwig bar set to the middle setting, I dont get any sway with the 7800lb truck and trailer hooked up.
35 yrs of driving 3.4 tons pickups. Have 2014 Crew Cab 4x4 5.7" box ram 1500. upgraded to tuftruck 1211 springs and bilsteins. which sway bar and end links do you recommend.
Probably going to go with LT truck tires, if I can figure out what to do about the 33" spare tire. if cannot figure out a spare tire option that matches 34, will probably do Michelin 33" p rated defenders.
Am bothered, no nd, by slight body roll on highway speed lane changes and super windy days, here in teh midwest. Oddly, all the roll seems to be rear end, not front.
What is the price for rear sway bar for 2015 ram 1500 sport 4x4 quad cab
Sent from my SAMSUNG-SM-G870A using Tapatalk
Is there any reason the Hellwig wouldn't bolt right up to an otherwise completely stock rear end on a 4x2?
May have to look into this. My truck always has a floaty feel even at slow speeds and rocks from side to side.
I'm thinking this would be a good addition for when I'm towing my 27' camper.
Matt, you said you run yours in the middle hole. What would be the effect if you ran it in the closest hole? Would it be really stiff (uncomfortable ride) or could you maybe risk bending the dinky looking stock links?
