Ohio chris
- Apr 8, 2017
- 1
- 0
- 2014
- 5.7 hemi
Has anyone found an aftermarket upper intake tube only from engine to the stock airbox for sale. Thanks in advance.
I think Legmaker is $300+
Jay
Stock tubing is not smooth throughout the inside...it's like corregated black drainage pipe. The S&B and leg maker are smooth to allow the most airflow into the throttle body. I paired mine into Moes 87mm. It's a real nice set up
And u cannot tell it apart from the oem unit. This is the way to go!!! With the S&B intake and snorkel you just about double the stock setup!!! Pair that with an opened up exhaust and custom tune and ur good to go.
Why would anyone do that? I get more air flow but you are deenginering the intake and cutting up your truck. Just stay stock if you can't afford it impo. These trucks are well built from the factory.There are threads by members that have cut a hole in the bottom of the stock box and bought tubing etc from like Home Depot and run the tubing to the front of their truck behind or beneath the grille forcing "clean cooler air" into the stock air box. This mod's seems to force more air into the stock system.
Jay
... The fact that I only spent $46, 3 beers, and 2 hours of my Saturday afternoon tinkering on my truck. I was happy with the end result.
