Definitely gonna need forced induction, cam, heads, a forged stroker kit, programming, fuel system upgrades, upgraded transmission, bigger brakes.
I want to get 550-600hp outta my truck i have a 2010 ram 1500 5.7L i got intake,custom tune,exhaust and throttle body spacer! What mods can i do to reach 550-600hp thanks
Moes Performance sticker to.You guys missed the most import HP booster, the "Catch Can"
rwhp? or at the crank. A procharger and a built transmission will get you there.
Well you can always upgrade your pulley on the procharger which should push you up another 50 hpJust for realistic comparison sake, I'm sitting at 501 RWHP with basically just a Procharger + water methanol kit. The only other thing I will probably do do performance wise is a set of long tubes which will get me to around 540RWHP I would. However, I'm at 5000FT elevation, so if you are around sea level, a Procharger + water methanol kit would surely get you at least 550RWHP or more. I have an 8-speed so I haven't had to do any transmission modding, but a 6-speed would definitely break under that kind of force.
I went back home for Thanksgiving, which is in a state near sea level, and oh boy what a difference!
Sent from my LG-H900 using Tapatalk
Full bolt ons and custom tuning will get you about 375-380hp to the rear wheels. Add heads and cam, and you will see about 430-440hp to the wheels. Add a 150 shot of nitrous, and you will be in that 550hp range to the wheels.
Boost is always an option, but not 1 that I recommend for a 5/6sp truck.
